Need help quick... How do you get the axle nut off??
I'm installing the mcgaughy's drop on my Denali at the moment, and I don't know how to get this crap off (the nut underneath the dust cap). Because the assembly just spins when you try to turn it.
Any Ideas...
Any Ideas...
Yeah, I am trying to remove the hub assembly from the spindle in the front. I took out the 3 bolts in the back, and I assume that I have to take off the big *** nut that is underneath the cap to get this off. Its AWD if it makes a difference. After I get the hub assembly off I will be good to go.
I don't have a camera with me to take any pics at the moment.
TIA
TIA
TIA
TIA
Location: Formerly Hayden, AL . . . Now Attleboro Falls, MA
Jam a large screwdriver (prybar, etc) into the cooling vanes on the inside of your brake rotor--when the screwdriver hits the ground (or brake caliper) it will stop the halfshaft from rotating . . . then you can remove the 32 mm (or is it 1 1/8 "? ) nut under the dustcap.
2002_Z28_Six_Speed
10-04-2015 01:34 PM
