Need a little more drop
Old 01-11-2007, 11:58 AM
dirtyratt's Avatar
Default Need a little more drop
2004 stepside by the way. I have the DJM 2/4 drop but I want abought a 1 inch more drop in the back what have you guys done to get alittle more drop out of the back...Thanks
Old 01-11-2007, 12:31 PM
KevinF56's Avatar
well you could do spring clamps to get a little more drop, but i hear that gives a kind of rough ride. also it doesn't drop it too much. it might be what you're looking for.
unfortunately if you need more than that, you might have to do a flip kit giving you 6 inches of drop, then put a 1 inch lift shackle netting you 5 inches of total drop.
or you could always throw **** in the bed.
Old 01-11-2007, 01:57 PM
02BlueStepside's Avatar
Either do the flip kit and 1" lifting shackle, or get a set of hotchkis 4" drop leafs, put your stock hangers on, and set the shackle at 1".
Old 01-11-2007, 02:46 PM
KevinF56's Avatar
oh good idea. i should have thought of that.
either way though you're looking at spending more money.
Old 01-11-2007, 02:54 PM
97Redbirde's Avatar
Dude take out your rear overload spring. It took me about 30min. just take the U-Bolts out and remove the center pin and take it out and put it all back together. You get about and inch and it drives the same.
Old 01-11-2007, 05:19 PM
dirtyratt's Avatar
or you could always throw **** in the bed. [/QUOTE]
LOL ,Thanks your FUNNY I needed that though
Old 01-11-2007, 05:21 PM
dirtyratt's Avatar
I might try that. Thanks for you help guys
Old 01-11-2007, 11:25 PM
StrokerAce03's Avatar
I took the overload out of my spring pack as well. It did give about 1" of drop but the axle wrap was so bad I ended up putting them back in and installed spring clamps. Doesn't give as much drop but doesn't have the problem with axle wrap. I agree with 02bluestepside about the flip kit and lifting shackles though; seems to be the best way to go IMO.
Old 01-12-2007, 07:54 AM
KevinF56's Avatar
if you do the flip kit with lift shackle you're most likley going to have to notch the frame if you haven't already.
Old 01-12-2007, 09:01 AM
97Redbirde's Avatar
Can I ask what you mean by axle wrap?
Quick Reply: Need a little more drop
