Need a Little Stall Education Loose? Tight?
Old 08-30-2009, 01:58 PM
Gregg Nader's Avatar
Originally Posted by therock
Looking into a stall and have no past experience in this field.
What does it mean if it's loose or tight?
What does "it flashes @ xxxx rpm" mean?
From what I read I guess if I want a little better performance with little or no MPG hit and daily drivability with occasional light to medium towing I want a 2800?
My truck specs in the sig.
Thanks
rocker, here are some links to basic information about how some of the modifications are made and there effects.
https://www.performancetrucks.net/fo...d.php?t=446072
Here are the results of some controlled tests that we did to better understand some of the variables when modifying converters.
http://www.transmissionspecialty.com...CTIP-05-07.pdf
http://www.transmissionspecialty.com...CTIP-06-07.pdf
http://www.transmissionspecialty.com...CTIP-07-07.pdf
http://www.transmissionspecialty.com...CTIP-08-07.pdf
Old 08-30-2009, 05:18 PM
therock's Avatar
Thanks Greg, And the others,
Looks like I'm not going to bother with it at this point.
Old 08-30-2009, 10:38 PM
TOWN CRIER
cheyenne383's Avatar
Therock, if you want to meet up you can drive my GMC, it has a PI Vigilante 2600 stall and will give you a good idea of what your truck would feel like with a converter.
Old 09-01-2009, 05:06 AM
therock's Avatar
Thanks, I would love an excuse to go to your bar. Do you ever get to the north Atlanta area?
Question.
I do lots of wildlife photography that takes me off road. At times I need to bump and crawl over logs and ruts and negotiate steep hills.
What kind of difference difference would a 2600 like yours make in these situations? Is yours a tight or loose converter?
Old 09-01-2009, 05:24 AM
Where's the Beef?
viciousknid's Avatar
You don't want a stall for climbing.
My Circle D 3000 is tight and it'll easily roll backwards on a slight incline if not on the throttle or brake
Old 09-01-2009, 07:03 AM
616 of 933's Avatar
i read that link but it still did not answer the questions above about loose or tight stall. I went with a TVS 2800 paid twice as much of the circle D. I am all stock but the stall does make the tranny temps higher and I have to add a cooler. You might want to budget a cooler in and a tune weather its a update or new tune. might want to add a shift kit and servos if not done yet. I did not look at your mods.
Old 09-01-2009, 08:11 AM
therock's Avatar
Thanks, I have an all Sonnax kit build with both their servos that works fantastic. I also have the OE trans cooler but could add to it.
Right now I am trying to get the feel of how a 2600 would behave in off road put putting.
I don't suppose anything less than a 2600 would be worth the trouble?
Old 09-01-2009, 08:50 AM
11 Second Truck Club
Cuerva's Avatar
Loosenes of tightness on a converter doesn't necessarily have to do with how low/high a converter is. A 2800 converter can be looser than a 3200. Normally you want a tigher converter for nitrous applications and a loose one for N/A. How loose or tight a converter is varies and also acts different on heavier vehicles, usually feels looser. I know with PI you can specify but it's always a hit and miss, same as stall size, some stall/flash higher than others even being the same size and some don't stall or flash as high as rated. I know for a fact a 9.5" is looser and flasher higher than 10.0" converters.
jscherbs
03-24-2017 07:20 PM
Go5.3tt06
25
09-04-2016 10:25 AM
Brandonlflr12
14
09-16-2015 12:44 AM
GM1697
09-09-2015 10:31 PM
GM1697
09-09-2015 01:52 PM
Quick Reply: Need a Little Stall Education Loose? Tight?
