Need Quality Drop for 05' VHO!!!
Who makes a 2/3 drop for my VHO??? My VHO's suspension has the same specs as a 2WD SS Silverado.
I want the best quality drop only! Money is not the problem or issue.
Keep in mind, my truck does not have front coil springs, it has torsion bars.
I'm ignorant when it comes to lowering vehicles. I do not know much about it.
The talk of control arms/ spindles/ shakles has me a bit confused. What ever is the best way to go, that's what I want.
I've also heard that some lowering kits do not work with Caltracs. I don't want that drop! I will be using Caltracs.
Who has the answer to "ALL" my questions???
Jim
Jim
McGaughys makes a kit for your truck...whether or not the rear part is compatible with Caltracs, I don't know. http://www.mcgaughys.com/ Probably have to use the t-bar key kit.
TOTM: January 2007
McGaughy's is probably the best money can buy for the VHO. With that kit you will be able to get a 2/4 drop. If you want anymore out of the front you need to use torsion keys. My bro used both torsion keys and spindles to get a 3/4 drop.
Caltracs will work for you application. Make sure you tell them you have a 4" drop with hangeres and shackles.
Here is a pic of my bro's trucks on 22's with a 305/35R22 tire.
At least that's what TXsilverado and I measured the other day. So a drop can only be 1" lower than the front.
I see that some are telling me the kit consists of a 2/3.5 drop. Maybe we mismeasured slightly, but I know there is not a 2" difference in ride hidth from the front to the back.
Thanks for the help guys. I will check these guys out.
Jim
13 Second Truck Club
Originally Posted by CHEVY6000VHO
Looks nice. Though my truck only has a 1" rake to the rear from the factory.
Jim
Jim
Originally Posted by nativetexan
I put the level and tape to mine and their is about a 1" difference also.
He told me that in 05' GM switched to larger front discs and in turn had to use a diffenent style balljoint. He told me that McGaughy's lowering spindles interfere with the balljoint and requires modifications to the spindles.
He also said that their customer service sucks as well.
He said Belltech, but uses McGaughy's rear hangers.
Jim
I posted on www.silveradoss.com a little bit. A moderator there told me to stay away from McGaughy's lowering kits for the 05' & up Silverados.
Jim
Jim
carid
10-28-2015 08:24 AM
SlvrSierra4.8
10-01-2015 09:39 PM
