need some help from someone ..
Old 09-15-2009, 07:35 PM
Formerly darynC-10/23/10
Daryn's Avatar
Default need some help from someone ..
okay so i was taking my connector off the side of the trans where the shift linkage goes... (the fat rectangular looking one), not the circle one... for the P_R_N_D_3_2_1......
and some wires came out of the plug....
can someone please take a couple pics of the wires and where they plug into on the little black piece on the side of the trans?????? PLEASE!!!!!!
thanks in advance to anyone who can help. !!!!
Old 09-15-2009, 08:37 PM
99ta's Avatar
Is it the same on my truck?
Old 09-16-2009, 01:04 PM
Daryn's Avatar
hmm it may be.. ill give u a call
Old 09-16-2009, 08:56 PM
99ta's Avatar
You got it with the diagram?
Old 09-16-2009, 09:40 PM
Daryn's Avatar
yeah i called tony and he told the number to color combination. had to redo the connector. but i got it done!!!!!!!!!
Old 09-16-2009, 09:47 PM
99ta's Avatar
Now all you need is a trans and you'll be good to go.
Old 09-16-2009, 10:58 PM
Daryn's Avatar
yeah........doh!
Old 09-17-2009, 11:29 AM
PT's Slowest Truck
budhayes3's Avatar
That's the neutral safety switch, I've heard that the connector is glued on and a bear to take off. When I swap my trans, I'm leaving it plugged in and just removing it from the trans and letting it flop. It has to come off of the trans anyway Sorry that I don't have a pic or wiring diagram for you though
Old 09-18-2009, 12:01 AM
Laid Back
Beatdown Z's Avatar
I also heard you can use a heat gun to help unplug it.
Old 09-18-2009, 12:53 AM
Daryn's Avatar
i used a small flat head and nd it came off fairly easy. it wasnt nothing bad
