Need some tall sticky tires....
Old 11-24-2006, 11:20 AM
How do I change this text
Wilde Racing's Avatar
Default Need some tall sticky tires....
like the title says, I need some tall STICKY tires.
I need to stay above 30.5 inch high, 16 or 17 inch rim, but I'd rather use the 17's.
I've searched around a bit here. I can find a few posts about 255 50 16
I'd like drag radials, but slicks will work.....
Can anyone point me in the right direction?
Old 11-24-2006, 11:36 AM
EvilChevy's Avatar
You might be able to get a set of 28x11.50-16 slicks for a good price ..
Old 11-24-2006, 11:39 AM
28 inch tall? If so that is too short.
Old 11-24-2006, 11:48 AM
11 Second Truck Club
Breeze's Avatar
The tallest I know of for a 16'' x 10'' wheel is the M&H cheater slick which is 30'' tall check out there web site.
Old 11-24-2006, 12:45 PM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Sticking with the 30.5" tire was impossible for me to go wide enough, but on a 16 inch rim you have some possibilities -- as long as it's a track only tire.
Old 11-24-2006, 03:55 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Call up M/T they were "suppose" to be coming out with a bunch of "truck" sized drag radials. They had one that was 30x12 IIRC.
Old 11-24-2006, 03:56 PM
1slow01Z71's Avatar
Try this thread
https://www.performancetrucks.net/fo...y+street+tires
Old 11-24-2006, 09:35 PM
Thanks for the link.
I looked at summit, but I can't seam to find any. I did run into a cool calculator, I don't want to spin the engine past 6000 I need at least 30 inch tires......
Front and rear.
What tires does Parish have?
Old 11-24-2006, 09:54 PM
1slow01Z71's Avatar
He ahs the 28.X nitto drag radials
Old 11-24-2006, 10:12 PM
Restricted User
NORCAL TBSS's Avatar
the trailblazer ss i worked on with a 150 shot went 11.4@121 on 275 40 17 drag radials. Just wondering why do you need tall tires. You need to be higher up in the rpm range going threw the lights and 30.5 will be to tall. 275 50 17 would be a good way to go also with the m&H racemasters.
Quick Reply: Need some tall sticky tires....
