Need some tall sticky tires....
How do I change this text
Originally Posted by NORCAL TBSS
the trailblazer ss i worked on with a 150 shot went 11.4@121 on 275 40 17 drag radials. Just wondering why do you need tall tires. You need to be higher up in the rpm range going threw the lights and 30.5 will be to tall. 275 50 17 would be a good way to go also with the m&H racemasters.
Edit. I typed 275 40 17, with that tire I would have too spin up to 6500 rpm..
So I guess 275 50 17 will work but I'd still rather have a taller tire. I would realy like to not go over 5500ish rpm....
Restricted User
sorry i forgot his redline is 6500.
his 60 foots are 1.5s and launch with the 150 shot off the line. his tranny gernaded on the 200 shot but his 1/8 mile time was 2/10s faster so it was a 10 second pass for sure. We are now looking into a powerglide for it because team that up with a big stall and a transbrake its the ticket. also guys that went from a turbo400 to a powerglide usually drop et anyway. he has a gear vendors overdrive unit that we will be bolting up also.
i know you prob dont want to do this but have you looked into the 15 inch mt drag radials. by far this is one of the best tires out there. they have a 325 50 15 that is sweet also.
on the trailblazer ss he had the m&H racemasters with 275 50 17 and launched it after the 60 foot mark with the nitrous because tires couldnt hold it and ran a 11.8@117 but bad 60 foot time on a 125 shot.
he then just changed to the 275 40 17 and i jetted it to a 150 shot and told him to lauch with nitrous off the line. 1.5 60 foot time and thing just pulled. 11.4@121. he said 2nd to 3rd shift it hung up a little which he adjusted with hp tuners. i installed his mt et streets and honeslty they are the best stickin tire around. much better than nitto or bfg.
i know rear it will but wait your 4wd right? im sure somone can answer that on here.
bluecajun5.3, thanks for the info, I'll have to check out screams set-up.
Looking for 1.5 60' s dreaming of something better......
James, Did you buy 4? or just 2? let me know how that work...
