New Drive Shaft
New Drive Shaft
I'm doing an 80E conversion on a project truck of mine. Its just about done and needed a custom length drive shaft built. I looked online at the big shops to learn a little about the parts needed and educate myself on the process. I have a friend at work who uses a local driveline shop for his 4X4 stuff. I went over there yesterday morning and ordered what I needed. I provided them with the 80E trans yoke, but everything else is new. Total price came out to be $278 after tax, which includes new straps and grade 8 bolts for the rear U joints. Not a bad price IMO.
I ended up with a 3.5" single shaft, with the correct 80E yoke on one end and the correct U joints on the other to mate with the GM 10 bolt rear. I told them it was for a performance application and needed to be balanced for high speeds. It turned out pretty nice, although its probably twice the weight of the stock aluminum shaft. I'll post a couple of pictures later.
I'm going to throw a coat of paint on it this weekend and see if it fits. Hope my measurements were right.
FYI - I took two measurements - one with the truck on the ground and one with it up on a lift with axle hanging by the leaf springs. It was 1/4" longer with the truck on the ground.
Yes I believe they are Spicer U-joints. I told the owner what I was wanting the drive shaft for and its intended HP level. He told me Spicer when I asked what series of parts he was going to build it out of. Not sure if he thought that was best, or most compatible with the existing 10-bolt.
Yeah, I was pretty happy with the price too. It came from Automotive Driveline and Supply, in Hurst Tx. It would have probably been another $80 if I didn't have my own transmission yoke. But thats still a good price IMO when compared to some of the big named online builders.
I told the guy its going behind a hot rod truck that should see 500+ to the wheels. He told me this setup was a typical hot rod configuration, built for higher speeds and should handle 800 hp. He said he would build one for higher HP than that, but price goes up...
I haven't installed it yet, but I did throw a coat of paint on it this evening.
Pictures attached:
Pictures attached:
Also, when painted, does that disrupt the balance since it was painted after balancing, or not enough to worry bout? My guess is no cause it's so little paint applied.
