New help with djm 4/6 kit!!!!!!!!!!
i just bought the djm 4/6 kit, and in the box theres no instuctions, and ive never done one before, does anybody know were a walk though with pics maunal is to install this kit?, any help would be greatly apreciated, thanks guys
You don't need the bags. And here is the response from my thread 5 years ago. Man in goes by fast
Edit: Just read through it again and the only thing I would suggest different, and did for that matter is do the notch after you flip the axle so you can make sure it is centered.
A 4/6 drop is kind of involved. DJM uses lower control arms on the front to drop 4". This means that you have to unbolt the spindle from the lower control arm to get it out. You will need a big hammer to get the lower ball joint out of the spindle (or a pickle fork that you can rent from Autozone or some place like that) A pickle fork is just an angled wedge that is hammered in between the two which seperates the control arm from the spindle. The front here isn't too bad, but putting it back together will take some compressing of the coil spring. (A good idea if you have any spare chain is to loop it through the center of the coil so it doesn't fly anywhere under compression) Place a floor jack under the lower control arm and compress it back towards the spindle. It might just lift the entire truck withough getting the new ball joint threads into the spindle if you have stiff Z85 coil springs from the factory. If this is the case, start loading your truck with weights on the side you are trying to compress the coil on. Put your buddy in the truck, free weights on the floorboard, someone else sitting on the floorboard etc... This should be enough weight to be able to compress the coil and lift the threads back into the spindle.
The rear is a flip kit with a 6"drop. You will need to section the frame for the frame notch. This part comes with instructions and a guide plate you bolt onto the frame to get your cut perfect. (at least the belltech flip kit that I did came with that guide plate) To cut, DON'T USE A TORCH. Extreme heat like that weakens these thin .083 tensile steel frames. Intsead use a sawzell (sp?) saw and be aware of your gas tank on the driver's side when you cut. You will then need to drill holes in the frame for the bolts that hold on the new notch. Then the axle needs to be put on top of the leaf springs. Take the leafs off and position the axle in the air on a jack and put the leafs under the axle shafts. There are nubs on the rear end that will line things up straight for you on this step.
You want your rear end housing (pumpkin) to be pointing toward the ground at rest. It should be at -2degrees. This is because when you give it a lot of torque (hitting the throttle) the rear end noses upward. So in on the throttle conditions, the allignment of the rear end will be essentially close to 0degrees. To make the nose of the rear end (driveshaft side) point downward, you would want the thicker side of the axle shim to be towrds the back of the truck.
There are many tools involved. Just try to think of all of them as you read through this and be sure to include a good floor jack and jack stands. The kits come with step by step instructions which should be way more useful than what I have briefly described Plan to have a ride for about two or three days though if you do it yourself. Perfection takes time
jacobrobertson2010
08-17-2015 06:20 PM
