New ring gear destroyed, need advice
Did you do the initial break-in correctly? If not, then it is possible to wear through the hardness. I had this exact thing happen to a set of gears I installed for a guy. I stressed the importance of the initial break-in because the gears get HOT the first few miles. I tell people with fresh gears to drive the truck for 30 minutes (no heavy hauling/towing/acceleration, speeds under 60) and then park it till the diff cover is not so hot that you can't hold your hand on it. If the gears do not get the initial work hardening, then you run the risk of the metal softening and the teeth deforming.
If you can, get pics of the pattern on the coast side of the gear teeth and post them up.
I have set gears up in 3k H/P Outlaw 10.5 cars at 3,240# and factory stock cars for Chrysler Dealerships for over 15 years... and I very much understand the difference between what the mfgr says vs. what the real world proves.
There is a reason I do not install Moser gears.
g
It's relative to the gears, the mfgr, the axle in question and the type of use it'll see.... typically if it's a street deal I don't let 'em see much over .006" - .008". If it's a soft race gear set on a 9" or bigger I set 'em up at .011".
g
g
I miss it already, driving a car w/138hp just isn't as fun as 400hp lol
Honestly, In my opinion that "break in" period is the responsibility of the installer. Bottom line in my opinion is that if a guy pays me to set up any gears in any axle, I expect him to be able to knock the hell out of it leaving my shop without recourse or fear of failure. I do not use mfgrs suggested backlash numbers, they will bite you in the *** every time.
g
g
So you do the initial break-in on new gears and then tell your customers to have at it right out of your shop?
As for backlash, most of the gears I set up call for 0.006" - 0.010". My target is like you stated, 0.006" - 0.008". The exception is new AAM gears in GMs which call for 0.003" - 0.006". I aim for 0.004" or 0.005" with those gears.
Castro45
24
07-31-2015 07:13 PM
Dezert1500
07-30-2015 02:51 PM
