Newly built Tans (mt TBSS)....fighting for 2nd gear, HELP!
I don't know why he would say NOT to. Dexron VI is backwards compatible and I actually put it in my trans instead of III because they gave my sister VI instead of III. It's a better formula that was created to meet the demands of newer transmissions.
The new formula reportedly improved Friction Stability 100%, Clutch durability 120%, foaming resistance 150%, oxidation resistance 100%, and maintains viscosity stability while Dexron III breaks down over time.
While you guys obviously dont have reason to worry about warranty, GM will NOT warranty a new transmission that had Dexron III in it.
Ok here's my question, how did he miss the pin being welded on if you supplied him with D-ring seals for the servo? The servo assembly needs to come out of the case to change those seals. It sounds like your build wasn't done properly to begin with, IMO the trans must come apart 100% for a build-up of any kind. Good luck.
Chuck/FLT
Chuck/FLT
MeanZ71,
I really hope the builder is not trying to sell you a bill of goods. It seems to me that maybe when he had an issue with second gear, he might have been the one to weld the end of the servo pin. This is something that some builders will do in order to tighten up the band when a problem with second or fourth is present.
I personally have never done this. When installing a HD-2 kit it comes with shims to adjust the band. Even before installing the pump you can check the play in the band and make adjustments from there.
In your case you are at the mercy of your local guy at this point. I hope that things turn out for the best and that you get your truck back on the road soon. Vince
***3/12 Update***
Tranny is in and shifting great now! He put a new kevlar band, drum, and servo pin in and also did a fluid flush. He felt bad he didn't catch the welded pin and wouldn't let me pay for any of the parts or labor (I offered since he has put soo much time in helping me). Overall he's a great mechanic and a great guy, just overlooked something he has never come across. Thanks for all the help and suggestions!
***3/12 Update***
If you feel like it....
Seeing as he would not take any money maybe send over some lunch for the shop, get him a case of beer, or even some doughnuts to show your appreciation. Just an idea if you feel you should do something for him. I think he would appreciate it.
Good to hear things worked out. Vince
Raggedz71
07-29-2016 11:20 AM
