NNBS drive shaft options.
Old 03-06-2015 | 10:35 PM
TAPyvehc93's Avatar
Ya, I said F-it and I am also going to a two-piece after talking to the DriveShaft Specialist. Anyone on here using their setup and have some pictures?
Old 03-06-2015 | 10:41 PM
iamkeniff's Avatar
I have their driveshaft
Old 03-07-2015 | 12:10 AM
TAPyvehc93's Avatar
Pretty easy to install? I gotta get under my truck and mock up the cross member so I can get some measurements.
Old 03-25-2015 | 09:13 PM
TAPyvehc93's Avatar
Finally got my 2-piece installed today. I got everything including the crossmember from DriveshaftSpecialists. I had a question about the angle of the shafts though. The way I have it set up now, both the front and the rear shafts are at about the same angles. Is this correct? Or should the front shaft sit level with the trans and then the rear shaft should have all the angle?
Attached Thumbnails NNBS drive shaft options.-img_1984.jpg   NNBS drive shaft options.-img_1992.jpg   NNBS drive shaft options.-img_1990.jpg   NNBS drive shaft options.-img_1982.jpg   NNBS drive shaft options.-img_1981.jpg
Old 03-30-2015 | 10:43 PM
iamkeniff's Avatar
Basically your trans and front shaft should "flow" into each other smooth. Then the same with the rear end into the rear shaft. No drastic drops or raises in the shafts compared to trans or rear end.
You can get away with adding 1-2* more downward angle to the rear end to allow for the shaft and pinion to be inline with each other under WOT conditions
Stock ecsb truck. See how the trans flows smooth into the front shaft?
Old 03-31-2015 | 06:21 PM
TAPyvehc93's Avatar
Okay cool. Mines looks like its in a pretty straight line, so I should be good. Still scared to go past 110 with it though lol, mostly do to these good years.
GXPJAY
02-13-2022 09:15 AM
Blue03sss
03-07-2019 06:06 PM
chopperloco
07-10-2016 11:45 PM
pjb1972
09-17-2015 03:06 PM
Ketis
07-23-2015 01:37 PM
