No crank spacer with 5.3L/4L80E conversion?
Old 06-30-2005, 03:34 PM
Adkoonerstrator
XLR8NSS's Avatar
Default No crank spacer with 5.3L/4L80E conversion?
Ok here is the deal. I got the converter completely engaged on the transmission. I measured things out so I know it is fully engaged.
There is 1 1/8" from the bellhousing face to the mounting lug face on the converter.
If I put the 4L80E crank spacer on, the mounting surface where the converter lugs will hit the flexplate are 1 5/16" off the back face off the block.
That is 3/16" too much.
If I take the crank spacer off there is 7/8" from the back of the block to the mounting surface on the flexplate.
That would leave a 1/4" gap between the flexplate and converter.
So should I just shim space between the converter and flexplate about an 1/8" with washers so the converter only has to pull out 1/8" or what?
I've never heard of anyone with the short crankshaft that hasn't used the crank spacer on their 4L80E conversion. Has anyone else ran into this situation before.
Why me?
PS - I have a SFI flexplate but, tried a stock one and it is the same distance off the block as the SFI one.
Old 06-30-2005, 04:08 PM
what a rush!
moregrip's Avatar
pics?
Old 06-30-2005, 04:33 PM
Adkoonerstrator
XLR8NSS's Avatar
What do you want to see?
All the measurements are accurate, I read a tape measure for a living and have gotten pretty good at it.
Old 06-30-2005, 04:39 PM
what a rush!
moregrip's Avatar
are you sure the tq converter is all the way on? I'm sure you have, but have you replaced a tq converter before?
I would like to see pics of the crank spacer.
Old 06-30-2005, 05:19 PM
Adkoonerstrator
XLR8NSS's Avatar
I'll get some pics for you.
I have replaced a torque converter before but didn't put it on all the way and blew up the pump.
I don't THINK that is the problem here but, will get some pics to try and explain what I'm seeing.
Old 06-30-2005, 05:24 PM
KySilverado's Avatar
Crank endplay? I've read about lots of issues with crank thrust bearings, especially after someone has been into their engine. Don't know that you have? Documents I have say that stock end of block to flywheel should be about .875. You are at 1 1/8 if I am reading your measurements right. The number I have is from different platform though.
Old 06-30-2005, 05:34 PM
Adkoonerstrator
XLR8NSS's Avatar
The end of block to stock flexplate measurement is .875 on my truck without the spacer so it's right on. With the spacer it it goes to 1 5/16"
The 1 1/8" measurement is from the front of the bellhousing on the transmission to the converter mounting lug.
So you can see I am missing about a 1/4" somewhere.
Old 06-30-2005, 05:45 PM
It all points to the transmission side. You have 1/4" clearance. It should be 1/8". Bellhousing to TC lug face should be 1" you are at 1 1/8. There is your 1/8 " Right?
I'd probably bolt her up and measure, hoping I'd screwed my measurements up on the floor. If I got the same thing I'd probably say screw it and shim it.
Old 06-30-2005, 05:51 PM
Adkoonerstrator
XLR8NSS's Avatar
No, I have NO clearance. The flexplate and converter are 3/16" too close to each other with the spacer bolted up. Evidently no one has ever done a 4L80E swap without using the spacer on the shorter crankshaft.
Without the spacer there would be 1/4" clearance but, the spacer is supposed to be there so I'm assuming it is a problem elsewhere.
I have pics I'm uploading and will post them in the other "crank spacer" thread in a minute.
**nevermind, this is the "crank spacer" thread.
Old 06-30-2005, 05:57 PM
Gotcha, errr finally. Yeah thats uffed up.
Quick Reply: No crank spacer with 5.3L/4L80E conversion?
