No overdrive
Yes you could pry on the cover to try to see how loose the assembly is. One mistake guys make when assembling these servo's is that they leave the gold washer off the servo pin that sonnax supplies. This needs to be between the servo pin "E"clip and 4th servo assembly. I think I have a pic some where if needed of how this should be assembled. I would think that if you forgot this washer the trans would not have worked as long as it did. I will say what AKlowriderZ71 has said is probably a reality. I just wanted you to verify for fact that the commands are there using a scan tool if possible. HTH Vince
