no overdrive 4l60e
inside this channel is the 4th gear feed, it flows through the center of the pin then inside the 4th gear servo cover pushing on the 4th piston, then pushing on the clip thats attached to the pin that engages the band, you may need a rubber attachment here but air check it and watch for band movement
