normal tailshaft play
Does this look like normal up and down play in my tailshaft. Side to side is the same. Seems excessive to me. it's a 4l80 to a 2 piece driveshaft on a 2wd ecsb Silverado
https://www.youtube.com/watch?v=MEji...ature=youtu.be
All that's less than 6 months old. Jakes stage 4 and a custom Driveshaft Specialist out of Texas driveshaft. I didn't install any of it so I'm not sure if it was sloppy from the get go or not. I've been noticing a little vibration that felt like maybe a u joint was going out, and that's what I found. I spent too much money to be having these problems already!
Is your suspension considerably different than stock? I think universal joints need a certain amount of angle applied when rotating to keep the needle bearings healthy?
Pulling a shaft is pretty damn easy. I'd do that, make sure the yoke isn't damaged and also inspect the needle bearings. Careful though.
lukn4trbl355
10-21-2015 11:19 PM
lxcoupe
10-04-2015 08:07 PM
TrickTurbo
09-23-2015 08:41 PM
