NP246 32 spline input bearing part # for 4l80e Swap
Old 08-24-2015 | 01:30 PM
tgui's Avatar
Default NP246 32 spline input bearing part # for 4l80e Swap
Whats the part number for the bearing needed to complete a 32 spline input shaft conversion on a NP246 transfer case? I have the shaft but can't get a good answer on the bearing needed.
Thanks!
Old 08-24-2015 | 04:58 PM
tgui's Avatar
I've been looking here:
NP 246 : , Cobra Transmission
Inner input bearing:
NP 246, Input Bearing (Inner) [411240] - $11.99 : , Cobra Transmission
Input bearing:
NP 246, Input Bearing [CT-325287] - $10.99 : , Cobra Transmission
I just can't tell if the inner (1st) or input (2nd) bearing is different for the 32 spline input shaft vs 27 spline. Arg!
Old 08-25-2015 | 09:10 AM
tgui's Avatar
I measured the OD of the 32 spline shaft. It was 50mm where the bearing (2nd) would fit. I think that a 27 spline input shaft would have a smaller OD because of the fewer splines. I'm guessing the needed part is thus the (2nd) link.
I'll order both to be safe and will post back exactly what part is needed.
Old 01-10-2016 | 08:40 PM
dobsnek's Avatar
I'm about to be in the same boat. What p/n was the right one?
Old 01-11-2016 | 02:52 AM
Dylpicle8's Avatar
Hold on. I'll try and dig up the part number from when I ordered mine.
Old 01-11-2016 | 02:59 AM
Dylpicle8's Avatar
Makco transmission part number 325287
You should be able to google "input bearing .630 wide np246" and find what you need.
Make sure to use anaerobic sealer on that t case, not just silicone gasket maker
Old 01-11-2016 | 11:54 AM
tgui's Avatar
^^ I think you got it right. I ordered both bearings and forgot the # of the one that worked.
Its the same bearing that goes into the stock 27 spine input shaft.
Old 01-11-2016 | 10:11 PM
dobsnek's Avatar
Thanks fellas, I appreciate it
iregret
07-27-2015 11:32 PM
Ketis
07-23-2015 01:37 PM
alex226
07-16-2015 11:55 AM
bsn1989
07-16-2015 09:20 AM
Aboss
07-09-2015 11:28 AM
