nv3500 questions
Old 03-14-2010, 01:25 PM
  #21
04600rr's Avatar
Originally Posted by sdimer350
just get a ls1 flywheel and pp. they can be had for nothing on tech. then buy the correct diameter 10 spline disc. i got my low milage ls1 flywheel and pp for basically what it cost to ship it.
i am interested in how you set yours up.......so you used a ls1 fw and pp then a 10 spline disc the diameter of the ls1 disc and i am guessing an ls1 slave. so pritty much an ls1 set up with a diffrent disc?
this could be key for my cheap set up....looking at prices if i bought all new items for the nv3500 i would spend the same if not more then buying a t56
Old 03-14-2010, 02:24 PM
  #22
04600rr's Avatar
after thinking about this for a few mins it only makes since that the ls1 flywheel would fit....you use the same starter when swaping to a t56 right....therefore the flywheel is the same diameter as the 4.8 flywheel. the only diffrence i would think is going to be the clutch disc surface area....
anyone know the diameter of a stock 4.8 disc and a stock ls1 disc?
Old 03-14-2010, 04:26 PM
  #23
makes children cry
_zebra's Avatar
i didn't remember that the starter was reusable with t56 (minus the GTO application)
4.8 is 11 7/8
Old 03-14-2010, 11:05 PM
  #24
04600rr's Avatar
looked up some after market flywheels and they have the same flywheel fitting both an ls1 and silverado. i guess the only way to find out is going to be buying stuff and taking the chance
Old 03-15-2010, 09:58 AM
  #25
makes children cry
_zebra's Avatar
where did you find that? i ask because when i called Summit & a couple other places, they told me an LS1 flywheel wouldn't work with the truck trans.
i ain't tryin to say either one of us is wrong, but i would like to know the answer.
Old 03-15-2010, 11:02 AM
  #26
04600rr's Avatar
http://www.jegs.com/webapp/wcs/store...atalogId=10002
these are not the stock flywheel but if you can use clutches from a truck or a car the only diffrence must be the disc contact area.....so if i get all ls1 parts and a 10 spline disc the same diameter of the ls1 disc it should work
Old 03-30-2010, 03:59 PM
  #27
04600rr's Avatar
just got a ls1 clutch/fly set up off ls1tech.....anyone know where i can get just the 10 spline clutch disk?
Old 04-05-2010, 12:10 PM
  #28
Registered User
FNGtotheLS2's Avatar
Default Thinking about doin that swap too..
i have a 2004 gmc sierra w/ a 4.8 mated to a nv 3500, thinkin about puttin in my t-56 into the sierra from a 1999 fire bird, which i swaped a 4l60 automatic in to. would the slave cylinder, bellhousin, and fly wheel bolt up to the 4.8 since the ls1 and the 4.8 r of the same bolt pattern? need advise soon because the t-56 is almost done gettin rebuilt. Thanks your info is greatly appricated.
Old 04-05-2010, 06:31 PM
  #29
makes children cry
_zebra's Avatar
bolts right up. i believe it takes a different starter, though. you'll also have to cut a new hole in the floor for the shifter
JordanH
12-25-2015 08:32 AM
projectnightcrawler
09-30-2015 10:49 PM
chevstang421
09-10-2015 09:16 AM
carid
09-10-2015 09:07 AM
andrewlong
09-08-2015 10:25 PM
Quick Reply: nv3500 questions
