OBS 14 bolt with 99-04 disc? Spacer thickness?
So here's what I have going on, I've put a 14 bolt SF rear end from a 92 into my 91 project truck and am planning to use 99-04 rear disc brakes but as some of you know the backing plate has to be spaced outward from the original location. I've seen a few spacers that guys have had machined but I can't find much info on the dimensions, some say 2.25" thickness others say 2.375". I already have my backing plates and calipers for the mock up just waiting on pads. I'm sure my best bet will be to just put everything in place and measure but I want to make sure my measurments end up in the ballpark of what others have done.
Custm2500's Rude Friend
According to this guy 2.25 is the magic number. https://www.performancetrucks.net/fo...-489403/page2/
I did mine differently. See EvilGMC Build https://www.performancetrucks.net/fo...thread-467473/
Well I bought some pads and bolts today then got everything mocked up and it would seem I need a 2.60" spacer
not really close to what others have used. Then I noticed my pads only contact half the rotor so it seems I've mismatched my brake parts, 08 Escalade calipers and 2000ish rotors. I'm guessing the escalade uses larger diameter rotors
are Escalade rotors also thicker? if so that should throw of the measurement right? Seems I need Escalade rotors or 99-04 calipers. Anyone know if there is a difference in the caliper brackets? if so will using a 99-04 caliper bracket move the Esky caliper down on the rotor?
![Name: Sept2012%20002_zps2f5fe5f6.jpg
Size: 159.4 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/129354d1501527013-obs-14-bolt-99-04-disc-spacer-thickness-sept2012%2520002_zps2f5fe5f6.jpg)
![Name: Sept2012%20006_zps6d3960af.jpg
Size: 131.3 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/129356d1501527013-obs-14-bolt-99-04-disc-spacer-thickness-sept2012%2520006_zps6d3960af.jpg)
![shrug](https://www.performancetrucks.net/forums/images/smilies/shrug.gif)
![Sigh](https://www.performancetrucks.net/forums/images/smilies/sigh1.gif)
![Name: Sept2012%20007_zps36d66b1d.jpg
Size: 139.7 KB](https://www.performancetrucks.net/forums/attachments/gm-drivetrain-suspension-22/129357d1501527013-obs-14-bolt-99-04-disc-spacer-thickness-sept2012%2520007_zps36d66b1d.jpg)
http://www.ebay.com/itm/CARDONE-14-1...f585d7&vxp=mtr
http://www.ebay.com/itm/CARDONE-14-1...254500&vxp=mtr
looking at photos of the two brackets there does seem to be a difference. I'm going to take mine to a part store and compare them, if it works it will be the cheaper option if not I'll just throw more money at it until it works out.
CARDONE 14-1110 Brake Caliper Bracket | eBay
CARDONE 14-1179 Brake Caliper Bracket | eBay
