odd noise
odd noise
well for once it isn't my truck...... my buddy has a strange noise coming from underneath or the rear of the truck..... initial thought to myself was gears..... but when he throws it in neutral it goes away..... what is it??? converter maybe?
thanks
thanks
there can be alot of noises dude...
Metal on metal sound?
I had a weird noise i couldnt figure out what it was...
i thought it was the front right hub, because when i made a left turn it would sound off.
Come to find out it was my Carrier Bearings..
Could be the rearend...and when the load is taken off(putting it in neutral) the sound goes away. Its hard to tell where sounds are coming from on a vehicle. You tried having someone ride outside the truck?(in the bed or in a vehicle beside it)
Banned
1 Post
jack the rear end up and put jack stands under it and block the tires and put it in gear and get it to make noise and see if you can tell where it is coming from
lukn4trbl355
10-21-2015 11:19 PM
