Official A4 to M6 (T-56) Thread!
Old 03-22-2012, 06:17 AM
  #991
DAH32's Avatar
Originally Posted by harley1247
Has any one ever put a ls2 gto and a t 56 in a silverado ?
I was, at the time there was not enough information out there about the difference in the cam sensor....I think now there is a adapter that can be used...you would be better off with a 6.0 in a truck since it is heavy and needs torque.
Old 04-04-2012, 01:00 AM
  #992
Ferocity02's Avatar
Has anyone gotten the reverse lockout solenoid to work when going from auto to T56? If so, how does one go about wiring it up?
Old 04-04-2012, 08:01 AM
  #993
xx_ED_xx's Avatar
reverse lock out just needs power and ground i used a push button and mounted it near the e brake. push and hold to put in reverse
Old 04-04-2012, 10:16 AM
  #994
Ferocity02's Avatar
Silverado_SS_04 wired his into the brake light, seems like a simple and effective solution
Old 04-04-2012, 11:21 AM
  #995
xx_ED_xx's Avatar
Until you are on the freeway slowing down to put it into 5th gear and end up grinding reverse at 80 mph...
Old 04-04-2012, 11:27 AM
  #996
Ferocity02's Avatar
Ah I was thinking reverse was over and down not over and up.
Old 04-15-2012, 09:23 PM
  #997
Ferocity02's Avatar
Will my stock extended cab 2-piece 4L60E driveshaft be the correct length for the f-body T56?
Old 04-15-2012, 09:25 PM
  #998
xx_ED_xx's Avatar
It should be, easiest way to check is measure trans with bell housing and compare to what you have
Old 04-15-2012, 10:36 PM
  #999
kren7604's Avatar
Not sure about the 2-piece driveshaft but on my 04 RCSB driveshaft I had to shorten the driveshaft 3" from 61" down to 58", to fit the t-56
Old 04-15-2012, 10:44 PM
  #1000
xx_ED_xx's Avatar
Was yours an auto or 5 speed
Quick Reply: Official A4 to M6 (T-56) Thread!
