Official A4 to M6 (T-56) Thread!
Old 04-18-2012, 04:34 PM
  #1001
Gummo's Avatar
Quick question about the console. I have an 03 so would I need the glove box to make it fit correct or is that only for 02 and under? Also, is the tahoe console the same as an ext. Cab silverado, avalanche?
Old 04-22-2012, 07:32 PM
  #1002
Ferocity02's Avatar
Is there anything special that needs to be done with the radiator? I think my transmission lines go into the passenger side of the radiator.
Old 04-22-2012, 07:51 PM
  #1003
xx_ED_xx's Avatar
Brake Cleen and spray the trans fluid outof the cooler so you dont have these small trani fluid puddles other then that no
Old 04-24-2012, 11:10 AM
  #1004
Ferocity02's Avatar
Finally got the reluctor done. It was pretty simple to make. I machined down the OD of the T56 reluctor, and machined up the ID of the auto reluctor, and made about a 0.003" interference fit. Then I heated the auto reluctor and pressed in the T56 reluctor. Boom, 40T splined reluctor. I did not center the auto reluctor on the T56 reluctor because the speed sensor isn't centered on the stock reluctor anyways, it's offset a small amount. So I tried to compensate for this. I haven't decided if I'm going to tack weld it yet. It was a damn tight fit.
Old 04-25-2012, 08:48 AM
  #1005
xx_ED_xx's Avatar
Good job, Always plenty of different ways to skin a cat
Old 04-25-2012, 11:05 AM
  #1006
Ferocity02's Avatar
Originally Posted by xx_ED_xx
It should be, easiest way to check is measure trans with bell housing and compare to what you have
The auto is 31.5" long from block/bellhousing surface to end of the tail housing, T56 is 31.25".
Winning
Old 05-19-2012, 06:54 PM
  #1007
Ferocity02's Avatar
I'm slowly getting my swap done, and the last big issue I have is that the cruise control doesn't work.
I am using the 40T reluctor wheel in the trans. I tried using the 4L60E sensor but it only works up to about 30 mph, then the speedo starts bouncing around and the ABS and BRAKE lights come on. The speedo is reding accurately minus the bouncing. I tried spacing the sensor closer and farther from the reluctor wheel and same result.
Then I tried using the T56 sensor with the 40T wheel and boom, speed works perfectly. No ABS or BRAKE lights, smooth as butter. But the cruise still doesn't work. It worked briefly at just over 25mph in 3rd I think. And I haven't gotten it to work otherwise, even at highway speeds.
I'm still on the stock 3.73 gears, 4.56's are going in soon. RPM in 6th on the highway is about 1400-1500 RPM. Calspeed tuned the computer. I told them about the 40T reluctor but I'm not sure if they did included it in the tune. I kinda think they did because the speedo is spot on.
Is there something in the tune that compares RPM's to speed before letting the cruise engage? It's weird that it worked for a bit and not again. Thanks
Old 05-19-2012, 08:35 PM
  #1008
xx_ED_xx's Avatar
Very odd, Well in my case i have a cable throttlebody and cable cruise control. I used the 4l60e reluctor and the 5 speed sensor and the calibrated the speedo with gear and tire size. I also went into tune and told it it was a manual trans. I think thats all i did
Old 05-20-2012, 12:04 PM
  #1009
Ferocity02's Avatar
What gears are you running, or what's your rpm in 6th on the highway? Does your cruise in any gear at any speed?
Old 05-20-2012, 02:06 PM
  #1010
xx_ED_xx's Avatar
3.42, 28 inch tall tire and yes works in all gears and speeds
even though i need to be above 80 for 6th
Quick Reply: Official A4 to M6 (T-56) Thread!
