Official A4 to M6 (T-56) Thread!
Old 02-13-2007, 09:17 AM
  #191
04GIBBS's Avatar
It works like the neutral safety switch more or less.
Old 02-13-2007, 09:44 AM
  #192
1TRUESS's Avatar
Originally Posted by 1969x11
Did any of you guys have to pull the controls off the side of your a4 and leave them plugged in to get the truck to crank?
Mine is still plugged in!
Old 02-13-2007, 11:26 AM
  #193
5 year bitches!
Quik's Avatar
shouldnt i be able to just jump it? cause that box is kinda fugly
Old 02-13-2007, 05:30 PM
  #194
When you find out how let me know because I dont like it either.And to think I thought it would just start right up HAHAHA!!!!! Nothing is ever that easy for me.
Old 02-15-2007, 12:02 PM
  #195
5 year bitches!
Quik's Avatar
im gettign ready to wire up my setup.... i need to know what everyone has done for all the plugs and etc
i know the Vss gets extended.
what about the reverse lights
neutral switch and etc
help a brother out
i found info on the reverse lights but any word on what wires to get clutch pedal to wire up?
how about neutral safety switch?
Old 02-15-2007, 06:44 PM
  #196
5 year bitches!
Quik's Avatar
i looked at my harness and wondering a few questions
i found a black wire, a purple W/white stripe wire...i believe these two are for the neutral switch...anyone knwo for sure?
i got a paper stating about what wires on a fbody to look for and the purple is one of them
has anyone wired up the clutch pedal at all?
does anyone know the wires on the pedal?
what is ppl doing with their little plug on the black box....im going to cut into the harness and take achance on what wires are what.....
sucks its a 50/50 shot for the green wire for the reverse switch
what is everyone also doing about the round plug?
Old 02-15-2007, 07:02 PM
  #197
It must suck to be the guinea pig , but will you please post up when you get it figured out because my **** is ziptied ton the side of the tranny.
Old 02-15-2007, 07:04 PM
  #198
help a brother out
Also what did you do bout the reverse lights.??
Old 02-15-2007, 08:35 PM
  #199
5 year bitches!
Quik's Avatar
ohwell got ot be something, lol
but yea ill post up when i get it figured out. i think im going to make myself a 2 peice harness. i already have a gromlet in my floor so i was going to run a set of wires to the pedal and then have a plug hanging down in the tunnel so i can connect it to the harness so its a plug and play ordeal..there is no way im keeping that box on side of my trans.
Old 02-15-2007, 08:41 PM
  #200
5 year bitches!
Quik's Avatar
well i ended up getting a plug off a junk Fbody harness. on our harness it has 3 thick wires, 2 light greens and a pink i believe....its a 50/50 shot which green is it...im going to go with the closer green to the pink and just mate those to the plug i got for the reverse port.
biggest downfall to any of my work is it will be some time before i run my setup...but hopefully with it in place i can atleast get the battery in a temp spot to check for my wiring
but as anything i will make sure to document it on this site so others can learn from me.
i also found out i didnt have to lenghten the VSS plug at all. was more then long enough
as for the skip shift...no need for it
for Reverse lock out...not using it either
Quick Reply: Official A4 to M6 (T-56) Thread!
