Official A4 to M6 (T-56) Thread!
#211
Originally Posted by Quik
i want to know specific wires for the cruise and and neutral safety switch...also want to knwo the 6wires on the clutch pedal
tune i got that coverd i do believe
#212
5 year bitches!
ok what i found out....
on the clutch switch you have these wires
Pin A PPL wire is for the TCC brake switch/cruise control release signal
Pin B brn/wht CPP switch signal
pin C lt grn igntion positive voltage
pin d ppl/wht starter relay coil supply voltage
pin e brn ignition 3 voltage
pin f gry CPP switch signal
on your A4 plug
Pin A orn/blk park/neutral signal
pin b lt grn park neutral position switch park signal
pin c pnk ignition 1 voltage
pin d blk/whit ground
pin e ppl/wht starter relay coil supply voltage
pin f lt grn back up lamp supply voltage
pin g yel neutral safetly switch park/neutral signal
i ran the ppl/wht wire from the A4 to the ppl/wht on pedal
i ran the Yel wire from the A4 to the gry on pedal
as for working havent tried yet
i did get wiring diagrams and went over it best i could to find out
on your A4 plug
#215
Issue
Have any of you guys ran in to the problem where your ABS and Service Brake light Soon comes on? My speedo is about 20 miles off and I am waiting for my new tune BUT I am wondering if it is because the speedo is so far off the ABS sensor is going crazy?
#216
#218
I'm curious as to what you come up with Quik. All I did was the back up light switch wiring. This will make it just one step closer to being a factory like install.
I hope GM is taking notes on this thread.
#219
https://www.performancetrucks.net/fo...d.php?t=385542
#220
5 year bitches!
on your A4 plug
on your A4 plug
PIN C & B are tied together when selector is in park
PIN C & F are for reverse lights
PIN G & E are for neutral safety switch
for PIN A its just a capped off wire that isnt in the harness [atleast for my 02 its not]
PIN D seems to be tied into the smaller plug for the black box
so tomorrow i plan on connecting the PINK [c] & Lt Grn [b] together so i have a complete circuit
and see where that gets me.
its only a matter of a few wires before i figure this out for everyone
