Official A4 to M6 (T-56) Thread!
#21
Part Numbers
Here are some parts I used!
Clutch Pedal - GM PART # 15027983
Brake Pedal Pad - 15706041
5-Speed Truck Cross Member - 15748078 - 2002
Z06 Flywheel/Clutch Package - 12570806 - had in truck for one year
Heavy-Duty Needle Roller Pilot Bearing - 14061685
Manual Transmission Steering Column Cover - 26072994 - makes for a nicer factory look
LS2 GM Flywheel - 12571611
LS7 Clutch - 24236500
Flywheel Bolt Kit ARP LS1 & LS6 Gen III 4.8 5.3 6.0 - 330-2801
Pressure Plate Bolt Kit ARP LS1 & LS6 Gen III 4.8 5.3 6.0 - 134-2201
#23
pedals
I found it easier to just order the pedals from the dealer for $65 for brake and clutch pedal. I am going to do the same transformation in my 06 silverado and found the parts at a dealer in Delaware pretty reasonable.
#25
Pedal
This is true.
I have to wait unitl my friend goes back to work so that he can make me an adjustable rod for my master cylinder so I can drive Mr. Gibbs. I hate looking at it and not driving it. My. Giibbs realeases all the way down on the floor board and I do not want to drive it this way. Just another note to some of you doing this that you may need an adjustabel Master Cylinder.
#27
Master
No man I paid my friend at the trans shop to do the swap for me. Here in Maryland it is a little to cold to be laying on our backs plus he only charged me $250 and it took him 2 hours to do it. But I would rather have the adjustability that way anything I do to it is just a simple twist of the rod away. You see I hate **** to be difficult or not work right the first time so thanks to you guys and my friends machine shop I have to be patient and what for this rod s that it will cure that problem.
#29
6 speed swap
I'm gonna be doin the swap in the next few weeks,I thought I would go ahead and swap in the 4.56 gears this weekend and ran into a few snags.1. I bought the gears and tru-trac from summit motive 4.56,s summit install kit they said I needed a diffferent bearing than was in the kit,ratech carrier bearings cant remember the part# but it was the wrong damn bearings. I came to find I just needed stock carrier bearings and races-99 nbs silverado.I also tried to reuse the stock pinion shim but it didnt seem to give me any preload on the rear pinion bearing, I'm gonna try and get a new chrush sleeve tues. and try to finish the gear swap.Swapping gears is not a fun job!!! Also if you buy the tru-trac and bolt 4.56 gears on it the friggin cap that goes over the hole in the unit wont work with 4.56's(gear is too thick) i had to get the porta band and cut part of the cap so it would slide past the gear.Its held in with a snap ring so it dont think it will hurt.This is how far I have got so far maybe better luck next week.
#30
gear swap
That is why i will only buy direct from the dealer. Thiis way you know the parts are right and they go in with no issues. Sorry for your problems 1969 and right before Christmans too?? Ahhhhh dammit man.
