Official A4 to M6 (T-56) Thread!
Old 11-13-2007, 07:43 PM
  #481
TurboGibbs's Avatar
-98-02 F body T56 will bolt right in.
-I'd recommend the LS7 clutch assembly. You can get the PP, disc and LS2 flywheel for less than $500. It is stout. I love mine and i've tried a few.
-Mcleod now makes a shifter relocation kit that moves the shifter to the front accessory hole and I believe the shifter attatchment for a 67 camaro is the most forward mounting i've seen. This will get you close to the factory hole though i've never measured exactly how close. If you use the factory T56 mounting location it will interfere with the cup holders if I remember correctly.
-You will need a custom driveshaft made as well as a yoke of the TH350/4L60e style. Your 5 speed uses the larger TH400/4L80e yoke.
-5 speed Crossmemeber needs no modifications. Trans mount fits right in.
-factory truck master cyl. works fine just mate it up to a 01-02 F body slave for best performance. You have to take the quick connect coupling off the f-body slave and put the truck hyd line directly on the slave using the roll pin.
-You will need at least a 4.56 or higher numerical gear for this tranny gearing to work (depending on tire size and engine torque) Your 5 speed has around a 4.02:1 first gear and the T56 has a 2.66:1 first. Besides the 6th will be too low to pull well and worthless up hills.
Oh, and mine was an original 4.8 5 speed.
Last edited by TurboGibbs; 02-01-2008 at 08:15 AM. Reason: corrected and added info.
Old 11-13-2007, 09:06 PM
  #482
RED04REGENCYRST's Avatar
there is some good info between me and a couple of other guys bout the t56 swap in a manual truck. i have alot of pics put in there of my shifter boot. check it out and let me know if i screwed anything up or if you have questions.
Old 11-17-2007, 01:59 AM
  #483
TURBHOE's Avatar
subscribing
Old 11-28-2007, 06:38 PM
  #484
TURBHOE's Avatar
Originally Posted by IMD
hmm well ive had the truck up to at least 80 and the speedo doesnt move. i have two plugs with a purp/blk wire and a grn/blk wire. and one plug with a grn wire and a yellow wire. ive tried them all, and i got nothing. is there anywhere online that has wire diagrams? the VSS plug is the one on the tailshaft area below the shifter and reverse wire plug correct?
my t56 has 4 plugs on it. one where the shifter is, one where the forward shifter would be, one on the pasenger side kinda in the middle, and the one on the driver's side at the very back, under the shifter....
any ideas?
did you ever get the speedo and stuff to work right?
Old 12-14-2007, 04:28 AM
  #485
04GIBBS's Avatar
changed my mine and bought an LS7 clutch
Old 01-04-2008, 04:34 PM
  #486
04GIBBS's Avatar
Still an awesome wealth of information.
Old 01-08-2008, 07:55 PM
  #487
TURBHOE's Avatar
anybody on here have electric adjustable pedals?
Old 01-08-2008, 10:46 PM
  #488
jkwalkercchs's Avatar
can u do this to the suvs or just trucks
and can it be done to a 4wd
Old 01-09-2008, 05:01 AM
  #489
TURBHOE's Avatar
yes, suv. not 4wd with t56. i mean you can anything is possible but it would be hard.
Old 01-09-2008, 11:40 AM
  #490
Lord Aries's Avatar
I talked to a bunch of trans shops/builders and NONE of them said they would use the T56 in a 4x4, Its just not made to deal with a transfer case... To adapt it would very expensive too unless you got rid of your t-case and did a divorced t-case (also very expensive)...
For a 4wd truck you can do the NV4500 5-Spd from the 1500-2500 trucks OR you could do like I did, the ZF6 6-spd from the 3500 Diesel and 2500 8.1L in my truck!
My ZF6 swap thread:
https://www.performancetrucks.net/fo...&highlight=zf6
Quick Reply: Official A4 to M6 (T-56) Thread!
