Official A4 to M6 (T-56) Thread!
Old 07-05-2010, 03:13 AM
  #791
xx_ED_xx's Avatar
Mine has worked fine so far...
Old 07-19-2010, 03:14 PM
  #792
2001CamaroGuy's Avatar
I love my T56!!!!!!!!!!!
Just got my T56 in this morning and it's everything I hoped it would be. I can't wait to get all the wiring done and get the interior put back together so I can go cruising.
Old 07-19-2010, 04:51 PM
  #793
xx_ED_xx's Avatar
let us know about speedo and cruise and abs issues
Old 07-19-2010, 06:03 PM
  #794
JakeBrakeIH's Avatar
x2!...
Old 07-19-2010, 06:13 PM
  #795
well speedo is working fine. I just hooked a new plug end onto the factory wire, changed the tooth count to 17, and adjusted the pulses per mile to reflect the 17tooth count (~50000 vs 110000 per mile).
Other than that, nothing works as of yet. I put set the A4 shift box in Park so I could crank and drive home. I also cleared all A4 related codes so I would not be hit with "reduced engine power" due to massive SES issues. I have not turned on or wired anything specifically relating to the T56 (such as clutch position switch or reverse lock out). I probably won't get to this stuff till end of the week/weekend.
Old 07-19-2010, 06:18 PM
  #796
xx_ED_xx's Avatar
Well if you fixed the speedo issues then the abs issues should be fixed as well since most of the trucks use the speed sensor to act as the rear wheel speed sensor as well. Let us know about the cruise issue.
Old 07-19-2010, 06:20 PM
  #797
5 year bitches!
Quik's Avatar
I have no issues with abs or anything else with my swap. Had it done since 07 with no issues. Just gotta make a hybrid file of a Fbody vs truck
Old 07-19-2010, 06:23 PM
  #798
xx_ED_xx's Avatar
Yeah but some people have had issues. I had my trans built and had them put the correct reluctor in. So I am pretty sure i wont have any issues. I just dont want to have to buy all the cruise control parts. since mine is a motor swap and the 4.3 cable wont work with my setup. I would rather find out up front if my cruise is going to be an issue.
Old 07-19-2010, 06:39 PM
  #799
I have no issues with my ABS because the VSS is reading correct in mine.
ED, I would say stick with the cable setup you have. You have everything so just use the cable TB and parts on the engine swap. Much easier and cheaper than buying all new parts to get the same end results.
Old 07-19-2010, 06:41 PM
  #800
xx_ED_xx's Avatar
um the 4.3 cable setup doesnt work with an 8.1 ls1 swap. I dont use drive by wire because no reason to buy all that extra crap when 2 cables will do just fine. But i am also converting the intake to use an az speed and marine monoblade so I am sure I will have to change the module to to ls1 type
Quick Reply: Official A4 to M6 (T-56) Thread!
