Official A4 to M6 (T-56) Thread!
Old 03-15-2012, 03:15 PM
  #971
xx_ED_xx's Avatar
yeah a flat piece of metal with a big enough hole in it to go over hex part, then i drilled a tiny hole for the retention bolt. I will look but i dont think i got any good pics of it. At the time everyone kept saying to tune it in the pcm and i wanted it to work correctly. Especially my cruise on long drives
Old 03-15-2012, 04:08 PM
  #972
DAH32's Avatar
Does the factory 5 speed sensor stick to far in if you dont shim it?
How thick is that piece of sheet metal?
What modifications did you do to the automatic reluctor to get it to fit?
Is that all you did?
Did you not have cruise before hand?
Old 03-15-2012, 04:39 PM
  #973
xx_ED_xx's Avatar
no shimming
no idea 1/8 inch mebbe it was a sbc engine block hook bracket
I didnt do the modifications but looks like they marked it on some of the splines and then took a punch and dimpled it to keep from spinning on the shaft.
Yes i had cruise but mine is not DBW
Old 03-15-2012, 07:29 PM
  #974
DAH32's Avatar
Originally Posted by xx_ED_xx
no shimming
What is the purpose of the bracket then?
Good Lord!
What is going on. That makes no sense.....marked in on the splines and dimpled it.....
Old 03-15-2012, 07:38 PM
  #975
xx_ED_xx's Avatar
the sensor doesnt have anything to hold it in, if you dont use the bracket
the reluctor is not splined so thats how they did it and it works
Old 03-15-2012, 07:42 PM
  #976
DAH32's Avatar
Ok, that plate actually serves to hold the sensor in....I got that now.
Is it the standard automatic reluctor?
The automatic has no splines and your saying they simple dimpled the inside of the reluctor to make it say put?
I would love to see some pics of that....
Old 03-15-2012, 08:01 PM
  #977
xx_ED_xx's Avatar
yes auto reluctor the 5 speed one has a much bigger hole, which i found amusing everyone couldnt believe the 5 speed holding up behind the bbc but then to find out the output shaft bigger then the viper one. I can draw it in paint since fero posted reluctor pics
Old 03-15-2012, 08:12 PM
  #978
DAH32's Avatar
Sure!!
Aarondah32@aol.com is my email if needed.
Old 03-15-2012, 08:37 PM
  #979
xx_ED_xx's Avatar
granted you will have to line it up with some splines
Old 03-15-2012, 08:47 PM
  #980
DAH32's Avatar
Ok...so those marks mean there is a mark on inside of that reluctor and those line up with some splines....makes sense.
If this is not go...maybe as been stated....take both the automatic and t56 reluctor and make one...
You would think a gear company would make something like this.
Quick Reply: Official A4 to M6 (T-56) Thread!
