ok guys i need yall help once again
![Unhappy](https://www.performancetrucks.net/forums/images/icons/icon9.gif)
ok so my 03 silverado 1500 2wd is messing up .just changed the inner & outer tie rods and upper & lower ball joints and just dropped it off at firestone for the life time aligment . ok so what is a good brand on drilled &slotted rotors cause i found some on ebay. and also i need to know whats a good brand wheel hub bearings if yall can help out fellas thank you in advance
You really found slotted rotors on ebay? Imagine that...
Make sure you get a good quality name brand rotor, Amazon had EBC rotors pretty cheap awhile back. I use Centric and have not had a problem with warpage and trust me, I USE THEM HARD.
Timken makes good stuff, both of my hubs were replaced with Timken. Check out Amazon for these too to save versus buying local.
lxcoupe
07-21-2015 02:12 AM
