ok I got my c-notch in, can i........
I have a 2004 Silverado rec cab sb lowered 4" with shackles/hangers, just installed my c-notch (DJM) can I remove my overload spring with out any fears of bottoming out. I assume I can since I added about 2.5 inches or so of new clearance. I do not haul or tow anything except for my big a$@. Does removing the overload change the ride at all, or just your hauling/towing capacity? I need about another inch of rear lowering to make it look like I want it .
Thanks in advance.
Thanks in advance.
02 w/ lowest mileage 2800
As long as you don't plan on hauling or towing anything you'll be fine, they only come into play then. I took mine out because my caltrac bars were hitting them, no adverse effects from removing them.
Hunt&Fisherator
The good thing is... It'll level you out perfectly and ride really nice, if you always go unloaded...
The bad thing is, you're towing and hauling will be history and wheel hop/axle wrap will be terrible without some sort of traction aid.
Your call...
Your call...
I have to disagree. I had no problems with my 00 after I removed mine and even had multiple bikes(MCs) in the back after wards. with the notch there is really no possible way for you to bottom out. You would need like 2 elephants in your truck. It will lower your truck about 1"-1.5"
GXPJAY
11-05-2015 06:49 AM
Porscharu914
08-10-2015 10:57 PM
