older 4l80e swap into 01 sierra ??
Old 11-21-2014 | 10:59 PM
hodge9386's Avatar
12 Second Club
Default older 4l80e swap into 01 sierra ??
i am swapping in a 96 4l80e with hd2 shift kit into a 2001 ecsb sierra behind a cammed 5.3. i already ordered a circle d tq converter for the swap but still need to find a crossmember. my question is about the nss on the side of the trans. the older 80e dosnt have the nss or a place to bolt it in. i know i can just bypass it and i will if i have to but is there a bracket or something i can get that will bolt the nss from my 60e to the 80e so i an use it? Question #2, i have heard that the new version of hp tuners you can do the segment swap yourself but im not exactly sure how to do it. is it just a matter of selecting 4l80e from the drop down or is there something else involved?
Old 11-23-2014 | 11:11 PM
dirt track racer 81's Avatar
I do have the tubular crossmember a needed for your swap. I had 95' in my 2000 truck and had no issues. You'll have to do a 4l80e segment swap in the tune.
Old 11-25-2014 | 01:43 AM
Ron_Stoppable's Avatar
You have to swap out the shift lever shaft to the the newer longer shaft that allows the NSS room to bolt up.
Old 11-26-2014 | 07:38 AM
hodge9386's Avatar
12 Second Club
I'm just going to cut my stock crossmember. I know I have to do a segment swap but I think with the new version on hp tuners I can do it myself I'm just not sure how to do it exactly. I am also working on something pretty trick to mount the nss and make it work. If I works I wI'll do a write up on it.
XL7
05-05-2022 02:48 PM
creekrat
08-02-2015 02:27 AM
lycominghunter
07-29-2015 05:24 PM
alex226
07-16-2015 11:55 AM
