Opinions wanted
11 Second Truck Club
Opinions wanted
I just swapped my spring/spindle 4" drop for uca/lca djm front drop. I was told it was for a 4" drop, but it looks to be a 3" drop. I have a 6" flip kit out back. I like the way a 3" drop rides over a 4" around my area, but the 4/6 "looks" better. Question is, would you....
1. put a 1" drop coil in?
2. cut the stock coil an inch?
3. raise the back up an inch with a lift shackle?
I like the LCA ride over the old spindle/spring setup. I had a mcgaughys 1" spring on my old 3" drop, but the 2" hotchkis spring on the 4" drop was too hard and I hated the ride. Thanks
If you got the money I would buy the springs! If not then just cut 1 inch off the springs in there now! I installed 2" springs and 2" spindles on a 93 rcsb that I have and a 6" flip kit on the rear and when I sat it down the front still seemed to sit high....at first i thought maybe I installed the springs upside down...lol...but I didnt and so I took them out and cut a inch and a half off the beltech springs to get the height that I wanted! I used a cut off wheel, not a torch...lol! Hope that helped!
I do like it, but I dont think 1" will make a diff. It did not on the old 3/4 from 2/4. I think its all in the spring. I used a mcgaughys 1" that rode nice, and made the truck handle better in the corners. I think i need to see how my 15x10" centerlines are gonna fit in the current stance before I make a final decision. I dont want them to hit the bed cause they will stick out past the bed on a 28/10.5/15 M/T slick.
I agree, I went back and searched tons of old threads where Ben, and Lance, and Skeet and others had done their coils, even David. i think it would be better to just cut 1/4 to 1/2 coil off, with about 1" more on the passenger side to fix any lean.
