Ordered drop kit FINALY, Got a few questions....
Old 04-07-2012 | 07:57 PM
Turbo 6.0's Avatar
Default Ordered drop kit FINALLY, Got a few questions....
So here is the truck as it sits right now with 2" drop shackles......
I just ordered some McGaughy's 2" drop spindles, 2" drop hangers and a set of Beltech SP shocks. I also got a set of new tires (stock silverado ss good years) and am getting the SS wheels coated in semi-gloss black.
The truck just ticked over the 75,000 mile mark and I am wondering if I should plan on replacing the ball joints and the hub assemblies when I install the spindles?
Also any opinions on the soon to come updates are welcome!
Old 04-07-2012 | 08:51 PM
black04's Avatar
Check them for play. If they're fine you can put it off for a bit. All the front end parts add up if you plan to replace them with good stuff. But if budget allows then you can change them.
Gonna look good with the drop on there.
Old 04-08-2012 | 12:27 AM
Turbo 6.0's Avatar
Sounds good! What drop/wheel tire combo you running? Truck looks Sick!
Old 04-08-2012 | 01:20 PM
Ferocity02's Avatar
If you have the money, you might as well replace them since you're already doing half the work to replace them.
Mine is 2/4 with 285/50R20's, basically the tallest tire you can run with this drop. I rub a tiny bit on the sway bar in the front at full lock.
Old 04-08-2012 | 04:56 PM
Turbo 6.0's Avatar
Where do you guys recommend getting the new front end components?
Old 04-09-2012 | 06:13 PM
Turbo 6.0's Avatar
anyone have part numbers for the hubs, ball joints (upper & lower) and tie rod ends?
Old 04-09-2012 | 06:15 PM
Ferocity02's Avatar
You could look it all up on RockAuto
Old 04-09-2012 | 08:35 PM
TIM Z's Avatar
11 sec. Truck Mod
Cool deal bro!
I also just ordered 2'' Mcgaughys drop spindles and rear hangers, already have 2'' shackles.
But thanks so much to stylin concepts for sending me the wrong front spindles, i have to wait another week to put them on. ******* douchebags sent me 2wd spindles, DUH!!!!
Old 04-10-2012 | 12:07 AM
black04's Avatar
Originally Posted by TIM Z
Cool deal bro!
What do you mean by 2wd spindles? All the 17+ mcgaughy spindles are the same and fit 2wd and 4wd. or did they send you 16+ spindles?
Old 04-10-2012 | 06:23 AM
TIM Z's Avatar
11 sec. Truck Mod
Yep, they sent me the 16'' part # 2000C for 2wd trucks !
I had to go on McGaughys website and tell them the correct part # i needed ( 33004) . This pissed me off, they should know what the hell they are selling. Stylins' customer service sucks. They dont even stock the parts, they drop ship, I should have bought from Summit Racing and will next time.
The part that infuriates me is they wont send me out the correct set of spindles untill they recieve the incorrect set back., So im screwed for another week, My truck is tore down on my lift and is stuck there for now.
