P0757 shift sol B code/limpmode still present after tune
Over a year ago I put in a yank tt2600 stall into my existing trans. My PCM was stock and the LS6 had been in and running for a long time.
Soon after installing the TC, I had TC lockup issues. More importantly, the trans would lock itself into 2nd gear and not come out of it almost every time I drove. The CEL came on and the code reader showed p0757 shift solenoid B test circuit stuck on.
I sent my PCM to wheatley for a tune, but mostly to eliminate this code and limp mode. Also had the shifts firmed up which worked awesome.
In the year + since then, it mostly went away. Maybe 2-3 times the trans would get stuck in 2nd gear, although the CEL never came on, but the code was stored in the PCM when I checked it with the code reader.
Within the last month it's happened about 4 times and it's becoming an issue again.
Was something with the tune not done correctly to remove this code/test/limpmode, or is it not something that can be completely eliminated?
For as small of a stall as it is, it doesnt seem to be worth the trouble considering the 50 miles per tank loss in mpg and the code/limpmode problems, so I might just throw the stock TC back in. If I choose to do that, is there anything in this modified tune that might cause future problems?
And it happened to start immediately (within 48 hours) after installing the stall converter? That's not a coincidence I can believe in.
Besides, as soon as you shut the truck off and restart it, it is back to normal again for a few days. I'd tend to think that if it were a hardware issue, it would remain "stuck" until it cooled down overnight or something.
Resident Retard
With that small of a Torque converter i doubt it is the converter causing the PCM to throw that code. I agree with the others is sounds like a hardware issue. Now if you had a larger stall RPM and smaller diameter converter i would agree it would be a tuning issue. I know mine would throw that code all the time when i installed my converter...
So I owned the truck for 2.5 years prior to installing the converter with never an issue, and magically the day after I install it, this recurring code comes up...yet it is not the converter? I agree, anything is possible, but that seems really unlikely to me.
So putting aside for the moment the slim possibility that this is a hardware issue inside the trans...
is there any further tuning correction that can be done beyond what you already did Mr. Wheatley?
Sounds hardware. I've ran a stall that size without at all tuning before.
Someone correct me if I am wrong, but I believe the sol b and sol a are the same part. You can try swapping their positions in the valve body.
Truck Sponsor
My check engine light no longer comes on when this limp mode condition exists, but the code still reads in the PCM when the limp mode exists, and I still have to clear it with my code reader.
So it seems like you set it not to activate the CEL, but I actually wanted the entire code/test removed from the programming completely (if that is possible).
lxcoupe
07-14-2015 10:14 PM
