P1870 on stock trans and converter
Yes it stands for pulse width modulation.
With the shift kit due to the PWM delete the TCC lockup feels about like a stock up shift does. Its noticable, not hard, I wouldn't even call it firm, but positive. The 93-94 4L60Es had no PWM at all it was a simple on/off circuit as it should be and they never gave any issues that I'm aware of. I'm curious if the PWM solenoid could be manipulated via tuning to take the place of actually changing the valve out to disable it. Could be the lazy mans fix until he gets his ambition built up to actually fix it.
I don't care what they say PWM started in 95 on the 4L60E. The ones that have it have PWM cast into the pump housing which mine clearly did as well as having the circuit in the connector for it as well as setting a code for the PWM solenoid which I had to turn off with tunerpro after I put the 4L80E in.
KyleW707
07-29-2015 08:17 AM
GMCtrk
07-17-2015 06:39 PM
grantpo
07-15-2015 12:21 PM
