Park to Reverse hard shift 80e
Old 02-14-2011, 09:57 AM
Gingervitis Addict
slow67's Avatar
Th400's and 80Es are known to have harsh reverse engagement. As stated its probably a high idle issue. A couple hundred rpm difference could be a difference of 100psi line pressure to 300 psi line pressure (this is normal and intentional for reverse in an 80E).
Old 04-18-2011, 12:31 PM
I have a gauge for that
Atomic's Avatar
I have another similiar issue...the trans is very difficult to turn in reverse, by hand or backing up. So much so that the truck has a hard time keeping a steady idle if I back up, as soon as I shift to neutral or drive its fine.
Old 04-18-2011, 04:04 PM
chevyrace47's Avatar
is it under warranty?
Old 04-18-2011, 05:13 PM
Formerly darynC-10/23/10
Daryn's Avatar
mine does it too... i have a stock converter though. im not worried about it.. im worried how long it will last behind 800 hp though
Old 04-18-2011, 06:21 PM
Vince B's Avatar
When you try to turn the output it will turn with more resistance in one direction and this is reverse. So this is normal. In most cases with a stall your idle will have to be increased for reverse and its pretty common complaint that the engine wants do die. I have seen this complaint many times with a 60 so IMO you have the same thing going on with your 80. Vince
Old 04-18-2011, 06:47 PM
Atomic's Avatar
Ok...I never noticed it with my 60s or my built 80e with the same current torque converter, just this rebuilt 80e.
Old 04-18-2011, 06:59 PM
GMCtrk's Avatar
I don't have the harsh engagement, but on a cold start if I don't wait for the rpms to come down shifting into drive the rpms will transiently shoot up to like 1300.
Old 04-18-2011, 09:15 PM
Formerly escalaradoon22s 5/2/10
Escalarado's Avatar
Is there any harshness when shifting into drive under the same conditions as shifting from park to reverse?
Old 04-18-2011, 11:58 PM
Atomic's Avatar
Nope. Its a firm apply, but not nearly as violent. I let blake and mitch hear it apply to reverse at the meet and both of them were kind of shocked it was so violent.
ARC
57
02-21-2022 10:54 AM
lxcoupe
08-31-2015 05:49 PM
lxcoupe
08-10-2015 12:20 PM
Ketis
07-23-2015 12:37 PM
MileHighSierra
07-12-2015 12:23 AM
Quick Reply: Park to Reverse hard shift 80e
