part number for trailblazer stall?
looking for the part number if anyone has any idea what it is. the convertor that is in the inline 4.2. thankz
Just figured I would be able to go pick up the convertor from the trans parts warehouse since they have pretty much all factory convertors in stock. I broke mine pulling out the engine and was needing one soon. idk how soon chris would send it over compared to going over to the warehouse in 1 day. plus i only wanted it temporarily since i'm actually wanting the 3600 later on down the line. but thanks. i will give him a call tomorrow.
well when removing the engine i pulled it out with the flywheel and stall convertor because i had seen that all the bolts that held the convertor to flywheel were stripped bad. must have been the previous owner or someone that worked on truck. anyways, while removing the engine little ***** fell out like bearings and then a lot of shavings were dripping with the trans fluid that it had. now i dont know where the bb's came from or anything but they were indeed falling out of the convertor. i know my truck was having trouble with the lock up for overdrive but maybe it was slowly wearing out? any idea where the bb's could have came from. I intend on using a 3600 stall but thats not until a little bit later down the line. I just want to try out the trailblazer stall. the one everyone says stalls to 2600-2800. I should be going for the stall tomorrow so hopefully i can get a part number or at least the year it came out in.
Former Vendor
You are looking for a 4.2 TB. Not sure what year is the latest, but the sticker on the converter should read VJCX. That is the 278mm style. We do have a modified version that flashes to about 3200. We also do quite a few upgrades for durability. But I understand the time frame and budget. Good luck!
Chris
exactly, i didnt know what to think of it either. first time i had ever seen that happen. This 4.2 tb should bolt right up to my 60e correct? and for this modified version you happen to build chris runs about how much roughly?
Former Vendor
5.3Caprice
11-07-2015 08:56 PM
iregret
07-27-2015 10:32 PM
