Parts Guy: "Lowering a truck will not cause a vibration....."
#43
I believe your issue is the shim. I believe that shim is supposed to be used with a lift block, which the hole is bigger. I ended up pitting on a rubican express steel shim. The hole is very small and i had to open it up a little. I have some ruff country shims that should be delivered in a week or so, which i will probably return.
#46
Yeah I used some shims where i had to drill the hole out, I went to autozone for the tr6's.
Yeah that pinion angle is atrocious Ferocity. But on my mcguahys drop I think i had to use some 4 degree shims to get it level again. My ridetech setup was dead nuts when installed.
cams 98 silverado
07-31-2015 07:36 AM
Suburban2500
07-14-2015 02:10 AM
