Performabuilt Level 2
Old 12-06-2009, 12:23 PM
SILVERBIRCH's Avatar
Default Performabuilt Level 2
Got the Performabuilt 4l60E Level 2 in so far I have been taking it easy on since it is still fresh and the truck still need to be retuned for it. I got it installed with a Circle D 2800-3200 Stall and a Tru-Cool 40k. I have been checking the fluid and it seems to be below the cross hatch area about 1/2" or so. I am curious if the cold weather and big cooler might be a factor causing this. A total of 11.5 quarts of Valavoline DEX/MERC were added at intallation does this seem about right? Should I wait to get it retuned and have it up to normal running temp. and then re-check or should just add a tad bit more for now?
Old 12-06-2009, 01:38 PM
stevenc's Avatar
I'd add more, performabuilt says that 1/2 under is bad, but half over is not. so having more is better then less.
Old 12-06-2009, 07:50 PM
LS1TECH & Trucks Sponsor
performabuilt's Avatar
Yes low at all is bad.
Frank
Old 12-06-2009, 07:54 PM
Where's the Beef?
viciousknid's Avatar
Frank
I can vouch for this. My truck keeps blowing it out for some reason and now it just sits there.
Old 12-06-2009, 08:13 PM
skeet's Avatar
fill it up and beat the chit out of it lol!!!
i did and do !!
after you get it tuned by the way
Old 12-06-2009, 11:52 PM
I have added a bit more fluid and its at level thanks
Old 12-07-2009, 12:20 AM
Z'06's Avatar
Looking forward to hearing how well that stall matches up with your cam!
Old 12-10-2009, 08:39 AM
I will keep you posted, going to Wheatley today for the retune.
Old 12-10-2009, 10:37 AM
CharlyNali6.2's Avatar
it going to be badasssss!!!!!!!!
Old 12-10-2009, 11:52 AM
Tootall's Avatar
we need some vids . . . and a few runs against some south side trucks
Quick Reply: Performabuilt Level 2
