PI VIg 3bolt TQ converter Q?
Originally Posted by moregrip
thanks guys, what length did you all go with? 20mm?
Originally Posted by DrX
Depends if you can find flange head bolts like OEM or need a washer. 20mm will be too long. That's all I could find and I had to cut them down. PI's instructions say 12mm- http://www.converter.com/book_flywheel.htm But I see that the instructions regarding the TC to flexplate clearance still say 1/16"-1/8" for all apps so who knows? It would be easy to determine now with the TC off. Screw a bolt in to the TC until it bottoms, then back it off a little. Measure how much thread was buried and add the thickness of the flexplate plus washer(if any). I can't recall exactly what I ended up with but I think it could be a little longer than 12 mm.
Cleaning up today and I found these on the workbench. Maybe PI did send me the right bolts and I got them mixed up with another pack of 3 black 8.8 bolts. Don't ask me where the smaller ones came from?? They are definitely M10 X 1.5 X 12mm. Add the extra thickness of any aftermarket flexplate to this for your bolt length.
