Picked up my verter today
Also, i crawled underneath it tonite to see what all will be involved in removing the tranny, WOW, lotta sh*t under there!!! how/whats the easiest way to get to the top bolt on the tranny?? im gonna do it myself, so any help would be GREATLY appriciated
11 Second Truck Club
remove the crossmember and let the weight of the tranny sag, this will allow the engine to tilt back some. then you will need a 2 ft. extension and a universal joint to get to it. the stud/bolt sizes are 13 and 15mm.
It took me awhile to do mine but mine is 4x4 and it was my first time doing it. I pretty much had no idea what i was doing when i started. Another member was guiding me through the instal by text messaging lol. Make sure you fill it up with at least 1 quart of fluid and make sure the converter is fully seated (1 1/8" from the bellhousing to the converter pads). Then when you bolt the trans back up measure the distance between the flexplate and converter converter pads. It should be between 1/16 - 3/16. If its more than 3/16 then you'll need to shim it.
I'd also pick up a shift kit if you dont already have one.
