pictures of shift cable bracket?
I swapped over the PRNDL switch to my new tranny in the truck. I installed the shift lever, then found the bracket laying in the corner of the garage. does anyone have a picture or can you tell me how this hooks up? i know its just two bolts, but is it before the PRNDL switch? I took this apart almost a year ago, my memory is rusty.
also, the only other thing that escapes my memory is where the vent tube goes. theres a small bracket on it, where does that bolt to?
There are two torx head bolts that mount it up to the trans, then there is that U shaped metal clip that has to slide through the plastic of the cable housing to keep it in place. Maybe somebody else has some better pics or explanation. My 06 is at home right now otherwise I would get some better pics for you.
Im looking for a picture of the body of the bracket mounted to the trans. I used the torx bolts to mount the PRNDL switch. what I am trying to figure out is if the bracket goes on first, or after the PRNDL switch.
thanks for your help so far.
