pictures of transmission (60e)
alright i have a decent picture of a transmission, im trying to find the exact place to put the temp. sending unit in the drivers side of the transmission. the only thing is that my trans has some black box cable system kinda thing on the side of it and it makes getting to the only hex plug i can see kinda difficult... does anyone have or can anyone take a picture of their transmission and point out where the sender would be screwed in? preferrably with the electric box on the side of the trans instead of the picture bear?
the green circle is where the elec. box/ cable wil be found and thunder550 circled in red where the port should be but does anyone have a pic with the box on it? i cant tell if the hex thing i see is that port to the left inside the green circle or if i see the one circled in red.
sorry for the rediculous post but i dont want anymore problems.
also, what should i use to seal the threads, not teflon tape, but what?
FormerVendor
The port that you trying to use I don't recommend. I would put it in a bung in the oil pan or in the return cooler line. There are kits out there for this and this method will give you a true reading. The main line pressure port is not a good place to mount the sender IMO.
Check out my pictures here
I agree with Vince - the pan is the better location for sender unit - mine is currently in the pan. But, I will tell you this: under my own observations and testing, I get the same temp readings from the pressure port as I do from my pan.
If you choose to use the pressure port, it is circled correctly (in red) in your picture. It is the only thing there, there is no mistaking it.
You need nothing to seal the threads, just tighten it up.
i dont really want to fool with the cluster, i used to have the temp port in a remote filter with auxillary port but the filter would impede the flow way too much and the line entering the filter, the other dy swelled and split so that made for a whole lot of smoke and a good scare so i bypassed that and now im looking for the easiest place to put the sending unit. sounds like the circled red place is it. vince, i value your opinion, why do you not like that location? not accurate? does anyone know what size the hex is on that port? is it 12mm? thanks for the input everyone, oh, vince, do you knwo where i could get a kit that you are talkin about if it really is not that good to put it in the main prressure port, if its non sponsor just PM me or something. thanks
-David
-David
FormerVendor
I don't feel that you get a correct reading. I believe this to be true due to the fact that when I run a trans on a dyno I use that port to test line pressure. We also hook lines up to the cooler lines as well. After 20 minutes of run time the cooler lines are much hotter than the pressure port line. I have worked with alot of tech's that say to put it into the pan or the return cooler line. After almost 12 years of dyno testing transmissions I believe they are correct. I believe a drain plug kit for a oil pan will work with a 1/8 pipe plug or you get a T and mount it into the return line. If you need one I'm sure we can hook you up!
Vince,
Im curious as to why putting the sending unit in the pan or the return line from the cooler is best? Wouldnt putting the sender in the pan only give you the temp of the fluid in the pan rather than what temps the friction surfaces are seeing? Same thing with the return line from the cooler...wouldnt that give you a false low temp reading compared to what the gear train/clutches are being subjected to?
Wouldnt the best place thats feasable to put the sensor be the "hot" fluid out line going to the cooler since that would seem to be where youd get the most accurate reading of the internal components of the trans?
FormerVendor
Originally Posted by myclone
Vince,
