Pinion angle clarification
Old 04-03-2012, 04:51 PM
black04's Avatar
You want it to be negative because thr pinion will point up when you're on the gas pedal. -1 or -2 degrees should be good.
Old 04-03-2012, 05:51 PM
TXsilverado's Avatar
Originally Posted by Ferocity02
If the pinion angle is negative then the working angle of the joint would be pretty bad I'm guessing. If I go with 4* shims then my pinion angle would be +1* and the working angle would be 3*.
i THINK 7* of operating angle is what they say the max is. look into it before taking my word. make sure you are measuring all of these angles on the ground with the suspension loaded. and on a flat surface
Old 04-04-2012, 12:18 AM
Ferocity02's Avatar
Hmm... I'll probably go with 6* shims then. What width do I need, 2.5"?
Old 04-04-2012, 09:18 AM
Dustinkgj1's Avatar
You are still missing half the equation. You need to measure the angle of your slip-yoke. In your case if your pinion is pointing up 3* then you want your output pointing down 4* the one degree difference is to account for spring wrap when on the throttle.
Tigger Welder
10-01-2015 08:41 AM
97_ek
09-23-2015 09:16 PM
03chevytruck
09-10-2015 10:18 PM
11MPG
09-08-2015 04:52 AM
Quick Reply: Pinion angle clarification
