(pinion angle) How to change my trans angle?
The only advice I can give about pinion angle is just listen or read a method you want or you decide on. Talking about this subject and others can lead to nothing but problems. None of would be wrong, but everyone would be confused. That is my experience. Regarding the shims, your talking about going to the track. The same thing can be applied to that as pinion angle.
Good luck to you.
Good luck to you.
I dont disagree.
What Im saying is this. When several instructors/several publications/several people/several sets of instructions or however you want to explain the correct way are being outlined, they may not all make sense to the person listening or reading. Usually when this happens no one can agree on anything about the subject once a question is asked or a discussion is started . The person that is learning or doing the work has to pick one that they are able to understand and go with that. In discussion, sometimes things can lead to mixups that causes arguments over the correct way by people saying this is better or that is better, nothing but confusion and arguments because thats how they learned, or they are miserable, or want to argumentative, or that is what they liked, or some other reason. This is what Im seeing on these topics like this. Opinions lead people not to be able to follow anything. This is because of the argument or discussion that is going on and often times leads them to be indifferent because of the egos in people wanting to say or see their way is better. Once that type of thinking begins in a discussion, at that point, any reasonable person will say, what is the point with that line of thinking? Most will say that is a terrible outlook. The only way to answer that question is for that line of thinking to totally go away, due to the reason that this line of thinking is the root of the problem.
Pinion angle happens to be one of these subjects that leads to this kind of explanation.
Your point is valid. There is no disagreement in what you said.
The problem is what I have explained in the opening paragraph.
Did I solve anything, more than likely, no. This is just an observation made.
Need to correct that U bolt too.
If your just driving around. Not being all that aggressive. That 4" shim will be ok. Most people with anymore than a 2" shim will remove the perches and rotate the housing and weld on new perches, especially if your doing any kind of racing.
Only if the pin (leaf spring bolt) is long enough to go thru the shim and into the spring perch a decent amount. That's why I welded a little extra length on the end of it. Everything located better and stayed put. I did slip the axle once before I did this little mod, no more issues after that.
I still stand by what I said at the 10:00 or #13 reply.
Have a good day.
Trendsetter
I want to be clear that the reason for me saying that line of thinking can go away is because I dont see a positive when things get to that point as in did in my reply at 10:00. That is nothing but destructive or dividing a camp and potentially creating problems. There is nothing there to be positive about. I prefer another line of thinking that is not even in that discussion. Im indifferent to that way of thinking and dont want to be part of that, who wants to destroy friendships or associations. When I see that. I say see you later, have a nice day.
