Pinion angle...and i have used the search button!
Old 04-17-2009 | 01:29 AM
  #21
lucky77's Avatar
Banned
Originally Posted by On20Z
Not to hijack but i am having the same problem at 40 the bed shakes like a sob.Just bought new wheels and had them balanced twice.I amlowered 5/8 with western chassis stuff so what would my pinon angle need to be on a 07 nnbs rcsb?
2005 silverado.I hope you get it fixed cause it is annoying.
its ur pinion angle , had the same problem after the drop, did u remove the shaft and put it back?
Old 04-17-2009 | 10:58 AM
  #22
Mark Johnson's Avatar
Hmm, learning alot here, as with anywhere else hanging around here, I'm gonna keep an eye on this one..................
Old 04-18-2009 | 01:45 AM
  #23
2005 Silverado's Avatar
SPAM HUNTER
Got the truck on the lift today. Ran up to 70 + (talk about nervous) vibrated. Took the wheels off, Still same thing, so that rules out the tires, also did front to rears, rears to front. I also used and ipod touch with a level on it (dont know how accurate) but it said pinion was up 2.2*
The real tool should be here monday or tuesday so i can check again.
Dustin
Old 04-18-2009 | 04:50 PM
  #24
On20Z's Avatar
Lucky,I did remove the drive shaft to give me more room on the rear end to cut old saddle pads off for c'notch clearance.How many degrees were you off.i am going to check tommorow.
2005,I just did all the tire rotating too.Im hoping the pinion shims help it.
Old 04-19-2009 | 05:36 PM
  #25
On20Z's Avatar
Ok how do i check this angle,i did it in park and then had my wife put it in drive and hold her foot on the brake and the driveshaft didnt even seem to move and difference,please let me know what to do.Here are some pics.
Old 04-20-2009 | 08:44 PM
  #26
On20Z's Avatar
Measure driveshaft and came up with 2*,then removed driveshaft and measured yolk and came up with -3*.So do i need a 1* shim,and if so 1* can cause the bed to shake that much.
Dustin how did you make out?
Old 04-22-2009 | 10:53 PM
  #27
SPAM HUNTER
Pinion angle was at 2* shimmed it up to about 4*. Vibration now starts lightly at 85 and is rediculous by 100. Should be ok for the track now with the 150 shot.
Dustin
Old 04-23-2009 | 12:06 AM
  #28
dlt76028's Avatar
Dustin
how is vibration ok? you should get it where theres none. 4* positive is not where you want to be. under acceleration and obviously higher speeds the axle will continue raising up untill it breaks. it needs to be -2* - 0*
Old 04-23-2009 | 12:23 AM
  #29
SPAM HUNTER
I went to 0 and the vibration was at all speed and constant. And also that comment was meant more as humor...like drive it till the vibration brakes the problem.
Dustin
Old 04-23-2009 | 12:34 AM
  #30
dlt76028's Avatar
you are measuring the trans shaft and diff and subtracting the 2 right?
Quick Reply: Pinion angle...and i have used the search button!
