Pinion angle...and i have used the search button!
#42
I have the 5.3 and it has the long *** alum/ shaft.
Can you tell me if your crossmember is built into the frame.
Do you think you could post up some pics of the set up?
It would help us out to try and find a fix for this.
#44
Man that would help out big time if you can get some pics so that we can see what the location of it is and if it has the same frame.
If so then I can order the parts but may need a vin # so the parts guy can look up them up.
#45
Replaced my trans mount yesterday. Overall loaded squish was just over a 1/8" more then new. I also increased to a 4* shim shimming the pinion down about 3.5*
Total measurements, transmission down 5* shaft is down 4.5* and pinion is down 3.5*
all numbers are approx you can only get a somewhat close reading with a manual angle finder, i think i might need a digital haha.
No vibration to 90, then minor vibration up to 110 i dont go any faster for traffic usually.
on decel i get a vibration, but i can understand that when the driveline gets unloaded.
Next im going to shim the transmission up to maybe 3ish*
Dustin
Dustin
#47
#49
Dustin
Dustin
