Pinion angle shims & c notch?
I have a 2/4 drop and I'm putting a c notch on soon. I want to do it ASAP but I'm confused on whether or not I need to adjust my pinion angle before I can mark where to place the c notch? I've read that the axle does not match up with the stock bumpstop when you lower it so you mark it before you cut your c notch but will a pinion shim move the axle to a different spot on Frame? Last thing I wanna do is c notch the truck and then I buy pinion shims and when I install them the axle starts hitting the side of the notch. Anyone know?
1. Remove the rear tires.
2. Disconnect rear shocks and sway bar (if equipped)
3. Jack rear-end up until it touches the frame.
4. Mark.
Don't overthink this. It's quite simple. If you don't want to fk with shims, I'd recommend the DJM flip kit as it gives you the ability to adjust the pinion angle to whatever you want.
Not the wheel base but I've seen pictures where the factory bump stops don't line up with the axle when it's jacked up.
The correct way to do this:
4. Mark.
4. Mark.
I'm already lowered and don't plan on going any lower right now haha but if u do want to go to a 4/6 from my 2/4. I have coil springs, hangers and shackles. To achieve the 4/6 what would be the easiest way to get to it. Could I just buy 2" drop leafs and then 2" spindles?
For the front, I would do spindles. Using quality shocks will also be needed.
mrobvious34
02-03-2016 10:43 PM
