Plannin on Eaton LSD install this weekend.
Originally Posted by LesPaul
have fun nonni i dicked with my rear for about 2 hours and still not right.... but this is my first rear i have ever put together
I dont know if I would use dicked and my rear in the same post. .
Harbor freight is where I got mine too.
Install writeup: http://bertok.us/agreif/eaton/eatontech.htm
im not sure man,
see if you can get someone to run the part numbers for you...
ED-19557-010** GM 8.5
Part Number Standard Package Requiredper Unit
ED-19557-010 Differential 1 Unit
29590-00S Preload System Service Kit - 400#
*Recommended for the majority of applications 4 Springs,
2 Plates 1 Set
29589-00S Preload System Service Kit - 200#
*Recommended for less initial bias 4 Springs,
2 Plates 1 Set
(optional)
29591-00S Preload System Service Kit - 800#
*Recommended for heavy-duty appliacations
*Not recommended for use with carbon discs 4 Springs,
2 Plates 1 Set
(optional)
99942-01S Lock Screw
*Does not require a lock washer 10 Pieces 1 Piece
EDS-29410 Gear Service Kit Side Gears,
Pinion Gears,
Wahsers,
Shaft,
Screw(s) 1 set
EDS-29426 Carbon Disc Service Kit
*Contains discs and guides for both ends Discs,
Guides,
Shims 1 set
EDS-29403 Steel Disc Service Kit (18 Discs)
*Steel disc assemblies are prone to chatter Discs,
Guides,
Shims 1 set
(optional)
EDS-29402 Steel Disc Service Kit (24 Discs)
*Recommended for use with 29591
*Offers higher torque bias Discs,
Guides,
Shims 1 set
(optional)
**This Eaton limited slip differential requires special bearings. For axles with small bearing bores (race O.D. of 2.89"), usually found on vehicles prior to 1999, bearing LM-102949 and race LM-102911 are required. For axles with large bearing bores (race O.D. of 3.06"), usually found on vehicles from 1999 to present, bearing LM-603049 and race LM-603012 are required.
2 Plates 1 Set
2 Plates 1 Set
(optional)
2 Plates 1 Set
(optional)
Pinion Gears,
Wahsers,
Shaft,
Screw(s) 1 set
Guides,
Shims 1 set
Guides,
Shims 1 set
(optional)
Guides,
Shims 1 set
(optional)
i just did this a week ago, usually if u swap sides with the shims it will mesh correctly. this info came from a very reputable gear shop. and it worked on my rearend. backlash was the same as stock.
