POSI Answer needed Yes/No
Originally Posted by gonzo 6.0
8 out of 10 times the factory shims will work pick up selective ones just incase.This was info direct from the head tech at Randys ring and pinion.Odds are the OE shims will put you in spec.I found it to be true with the two I did.
Get the selective shims like M said, they are easier to work with and you have total control over backlash and preload.
14 Second Truck Club
Originally Posted by DynoDR
Probably on about 8 out of 10 that I do they would NOT work. I see no need to try and reuse a factory shim as cheap as the selective packs are, especially when you buy a install kit.
Everything that is in a basic install kit is the MINIMUM you would need for a gear install. You would not need the pinion seal, nut and shims. But, the kit would still be cheaper than buying individually.
Originally Posted by mzoomora
You can never be over-prepared. I have never reused diff shims, and have never been in a rear where I thought I could. It only takes a few thousandths to be off on preload and backlash. I have reused pinion shims before, many times, but that is only after taking measurements to see where I am at.
Originally Posted by Baumgardner2051
You said "Never been in a rear"
Seriously, with all the extra parts I need to order, would it be easier and close to the same money to just buy a brand new eaton posi? Wouldn't it come with all the shims, bearings etc.... that I need? Or would I still need all these parts with a NEW eaton? I'm not changing gears or anything fancy, just a better posi so I don't destroy the rear end after the radix get finished.
He he, he he, I said "do it"
